Forums >> Revit Building >> Technical Support >> walls revit 2008
Thu, Jun 21, 2007 at 9:37:52 AM | walls revit 2008
triston
Does anywone know how to make curved wall with profile such as curved retaining wall that conforms to grade?
Thanks
Thu, Jun 21, 2007 at 12:09:18 PM | walls revit 2008
broncos4life
3.5 Stars: 11 Votes
Massing, use massing and creating the curve of the wall, and then do a void form of the mass in elevation to reflect the grade.  Then use wall by face.  Then just turn off massing so they dont print.
Note:  There is a glitch with this, (at least there was in 9.1, not sure for 200Shadey if you use a True Cylinder and then Cut it in elevation it will not reflect to wall by face, my recomendations are to stay away from cutting a true cylinder.
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
Inexperienced in creating families from scratch in Revit 2008... Help please???
Sun, May 2, 2010 at 5:00:11 AM
how to import revit 2008 data to autocad 2008????
Tue, Apr 8, 2008 at 10:12:03 PM
REVIT 2008 - How to avoid Problems?
Sat, Mar 22, 2008 at 8:47:05 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:43 PM
Page generation time: 1.6116
