Forums >> Revit Building >> Technical Support >> Parameters for Consultants?
Wed, Jun 20, 2007 at 10:03:42 AM | Parameters for Consultants?
PhotograFord
So, I was wondering if it's possible to set up new parameters for tags for consultants (structural, MPE, Electrical, Civil, etc) Similar to a 'Client Name' and 'Client Address' tag? If so, how?
Wed, Jun 20, 2007 at 5:32:59 PM | Parameters for Consultants?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes of course.  Read up on Shared Parameters...
Remember these will also need to be loaded into the Project Parameters section for each project you want to use them in otherwise the field will not be editable.
Regards,
Chris.
Working with Consultants
Tue, Sep 28, 2010 at 9:29:57 PM
Finding Consultants who use Revit
Thu, Mar 10, 2016 at 1:45:54 PM
Limit Revit Access to certain consultants within Collaboration for Revit
Fri, Jun 1, 2018 at 2:50:05 PM
Work with Consultants Workflow
Sun, Jan 28, 2018 at 6:03:06 PM
Searching for consultants to use Revit
Wed, Jun 23, 2010 at 4:47:51 AM
Page generation time: 0.4515
