22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Can I use views from 2 different projects in one sheet?
1 Posts No Rating |
We have a giant building we're doing that has been split into 3 separate Revit projects. One is the shell & core, one is the bottom 4 floors, and one is the tower, which is floors 5 and up and occurs only in one part of the building. I'm supposed to be doing the stair and elevator plans and sections. In order to do the sections, we've created a composite project which uses the other revit files as linked files. The problem is that we can't work in those. What we would like to do is do the section sheets in the composite file, but do the enlarged stair and elevator plans in the project files they exist in. So my question is, how can I show stair #1 first floor plan and stair #1 5th floor plan on the same sheet if they are in separate projects? Is there any way to do this? Thanks.
Sheet Underlay |
Fri, Sep 12, 2014 at 2:13:25 PM
Save a sheet of drafting views |
Wed, Mar 1, 2017 at 5:34:28 PM
Extracting Sheet views which were created before switching to Central File |
Tue, Jan 19, 2010 at 10:11:01 PM
adding views to a sheet from another file... |
Tue, Jan 3, 2006 at 10:40:04 AM
Manage Sheet Issues / Revisions across linked projects |
Thu, Mar 17, 2016 at 3:35:39 PM
