Forums >> Revit Building >> Technical Support >> Materials
Thu, May 24, 2007 at 8:33:12 AM | Materials
Marc9999
Hi,
I'm trying to indicate polished blockwork which courses at 275mm.  I have made up a materail with a surface pattern using a fill pattern with what i thought was the correct distances apart.  However, this worked on my elevations at 1:100 but not a section at 1:50.  Is it possible to create a fill pattern which will stay constant no matter what the scale is?
cheers
marc
Thu, May 24, 2007 at 3:36:03 PM | Materials
framerman
4 Stars: 13 Votes
sounds like you have used a drafting pattern instead of a model pattern. I don't know many that use the drafting pattern, though there is uses for it. If you can't find a similar model pattern, you can edit the hatch file to make it a model pattern. Check your help file for that, it's pretty simple.
Fri, May 25, 2007 at 4:16:40 AM | Materials
Marc9999
cool, that work a treat.
Just 1 more question!
How does revit determine the setting out point of these materials? Is there a way to use like a snap base point?
thanks for your help
Fri, May 25, 2007 at 7:22:44 PM | Materials
framerman
4 Stars: 13 Votes
I'm not sure what you mean by setting out point. If you are trying to position your hatch a certain way, you can use the align tool for your hatch lines. Click "align" then position it over one of your hatch lines and if it doesn't highlight, hit tab a time or maybe two and it will highlight.
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Missing Materials
Wed, Jun 19, 2013 at 2:22:26 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
replacing materials in multiple family files?
Wed, May 6, 2009 at 7:13:40 AM
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:55 AM
13
Page generation time: 0.3304
