Forums >> Revit Building >> Technical Support >> line weights, elevations, and clipping
Tue, Apr 24, 2007 at 2:21:30 PM | line weights, elevations, and clipping
pgrimmi
ok so here is my problem. i have created a bunch of interior elevations and the limit line of the clip in the elevation is creating havoc on my wall and floor line weights. if i pull the clip line back the walls have a heavy lineweight as they are being cut. when the clipping box is snapped to the face of the wall it loses its lineweight, same for the floor! am i doing something wrong? thanks for your help!
pgrimmi
Tue, Apr 24, 2007 at 5:02:26 PM | line weights, elevations, and clipping
pgrimmi
along similar fronts, is it possible tobreak an elevation so that it staggers and does not cut through some casework that i want to avoid?
Fri, May 11, 2007 at 2:38:23 PM | line weights, elevations, and clipping, does anyone have an answer?
pgrimmi
otherwise, i will have to go into each elevation and adjust the crop region so that the correct lineweight shows up. seems like this should be something basic that can be easily corrected!
thanks again!
pgrimmi
Fri, May 11, 2007 at 4:14:06 PM | line weights, elevations, and clipping, BTW i am using 9.1
pgrimmi
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 1.6518
