Forums >> Revit Building >> Technical Support >> Revit Imported file Dashed/ section marks
Tue, Apr 10, 2007 at 5:14:24 PM | Revit Imported file Dashed/ section marks
Marmar
Hi everybody
I have two problems in different files.
In one of the files, I imported a Revit Building file from the architect, into my Revit Structure model and it looks dashed in the structural plan views, not in 3D view. I check visibility and object style, I reload, audit and remove the file and nothing works.In other project I make some sections in the structural plan view, and after I couldn’t see them. I still have the sections but I am not able to see the marks. I check visibility again and I should be able to see the marks but I am not. Do you know what could it be?Thanks
Strange Orange Section Marks and Images that get imported as negatives [ 1 2 ]
Thu, Jul 4, 2013 at 9:59:33 AM
18
section marks
Tue, May 17, 2005 at 12:54:13 AM
Section through a family object and imported dwg file
Fri, Mar 26, 2010 at 12:41:24 PM
Section marks appearing on plans
Thu, Dec 6, 2012 at 4:26:26 AM
Section cut through the imported dwg file
Wed, Jun 26, 2013 at 4:00:40 PM
12
Page generation time: 1.6338
