Forums >> Community >> Newbies >> Foundation- Revit8
Wed, Mar 14, 2007 at 6:29:28 PM | Foundation- Revit8
batonrougeart
I am currently learning revit 8. I have the book from SDC, but am having trouble forming the foundation. I set up the walls, interior and exterior, then came through with the floors. But no concrete slab, or footings. Anyone have any suggestions for me on completing this? Any help will be GREATLY appreciated. Thanks guys....
Sun, Mar 25, 2007 at 8:08:03 AM | Foundation- Revit8
Dgodfrey
4 Stars: 4 Votes
I generally make the floors one of the last things to model. Just one more line to tab through when aligning walls. You can build your foundation from either the foundation level and overlay the walls above to assist in placement or my prefered method is to model the foundation walls from the first floor and set the location of the foundation in the properties dialog. This allows me to accurately pick the core of the stud wall as the reference for the exterior side of the foundation wall. When using overlays, the core is not visible (you can however offset your new walls if that works better for you. I tab through the wall so that it picks all attached walls and if everything aligns properly, you can build your entire foundation perimeter in 5 seconds.
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
foundation wall tag
Wed, Jul 22, 2015 at 1:22:24 PM
Foundation Thickening
Thu, Jul 3, 2008 at 9:39:52 AM
foundation corner cleanups with setback
Fri, Aug 26, 2016 at 11:54:14 AM
Newbie Grid Question Revit 2008
Tue, May 15, 2007 at 1:19:39 PM
Page generation time: 0.0580
