Forums >> Revit Building >> Technical Support >> Dwg’s linked into Families
Mon, Feb 12, 2007 at 9:41:51 PM | Dwg’s linked into Families
brenehan
Hi
I need a little guidance in creating Families, where I want to use some old dwg files to speed up the process. I’m using Revit 9.1
Ok here is an example of what I would like to be able to do!
I want to create Revit Title Blocks.
In doing this I have opened a standard Revit Title Block Family from the Library.
To speed up the process I would like to insert my old AutoCAD title block. Draw over it, and then remove the DWG file from the family.
From my understanding of Revit, it is a good idea to bring the dwg file in as a “link” and this makes it easier to remove, (ie through link manager).
The problem is,
When you are creating a family, Revit allows you to bring in a dwg file, but not as a “linked” file.
Any ideas?
Thanks
Brian :-)
Tue, Feb 13, 2007 at 8:17:53 AM | Dwg’s linked into Families
coreed
coreed Avatar
4 Stars: 16 Votes
i think that advice does not include when making families, as far as i know
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Bathroom families sometimes disappear in Linked Unit Files
Fri, Aug 3, 2012 at 6:17:33 AM
Linked files in families
Tue, Oct 30, 2012 at 7:40:31 AM
Adding families to linked files in a project.
Wed, Sep 8, 2010 at 7:01:41 AM
Faced-based families Revit Systems
Wed, Oct 3, 2007 at 6:23:30 PM
Revit imported .rfa famiiles linked?
Mon, Jun 3, 2013 at 2:57:27 PM
Page generation time: 2.0082
