48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Roof plan help
Thu, Jan 25, 2007 at 4:31:47 PM | Roof plan help
TJKENNEDY
3 Stars: 2 Votes
Hi, I am new to revit structure and need some help with a roof. In the clouded area of the model I have attached, I cant quite get the slopes to line up correctly. I need a 6/12 slope on everything but the small piece between the clouded dormers. That section needs to slope from the eave to the peak of the two dormers.
Edited on: Thu, Jan 25, 2007 at 4:34:53 PM
Thu, Jan 25, 2007 at 6:50:55 PM | Roof plan help
framerman
4 Stars: 13 Votes
No attachment, but from the sounds of it, you might try the roof by extrusion method in a side view. it sounds like you have a different roof pitch there I'm assuming?
Fri, Jan 26, 2007 at 11:47:25 AM | Roof plan help
TJKENNEDY
3 Stars: 2 Votes
Ok, i think it worked this time
Edited on: Fri, Jan 26, 2007 at 1:10:33 PM
Fri, Jan 26, 2007 at 12:14:53 PM | Roof plan help
framerman
4 Stars: 13 Votes
um....still no attachments. your attachment larger than 2 mb's by any chance? can you post a screenshot instead?
Fri, Jan 26, 2007 at 1:11:19 PM | Roof plan help
TJKENNEDY
3 Stars: 2 Votes
*shameless post bump*
Fri, Jan 26, 2007 at 5:22:28 PM | Roof plan help
framerman
4 Stars: 13 Votes
hehe, np. yeah, it's just like I said before, you would do good with a roof by extrusion from the side then clean up the roof from the plan view. I hope you didn't mind, but I cleaned up your roof edit lines to match the imported dwg file. It was difficult to see since both lines were purple in color. check out the roof I did and the openings I made.
Sat, Jan 27, 2007 at 2:34:26 AM | Roof plan help
TJKENNEDY
3 Stars: 2 Votes
Thanks! That looks great. I attempted to duplicate what you did, and was successful, so I think I might actualy have the concept down.
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Roof plan
Fri, Sep 2, 2016 at 4:58:14 PM
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
Creating a Roof Plan in Revit
Wed, Oct 3, 2007 at 8:51:58 AM
missing roof in roof plan
Thu, May 7, 2009 at 11:40:59 AM
Page generation time: 0.7844
