10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Create Templates from Central file
4 Posts No Rating |
I've been working in a project that was set with worksets. Now that the project is done I'd like to make this fil (rvt) as a template (rte) for next similar projects, but revit doesn't allow me to save the file as template because worksahring is active in the file. Does anyone know how to "eliminate" the worksets in the file or how to create the template from it?
Once worksets are enabled they cannot be undone. Your best bet is to start a new project with no template chossen. Then have the Central file or local copy open and go to the new project. In the new project use File>Transfer Project Standards and choose your worksetted file. This will bring most everything over. When done, save your new project as your template.
Tom www.reviteer.com http://twitter.com/Reviteer |
4 Posts No Rating |
Thanks Tom, I did transfer the project standards into a new file, but things like sheets, details and all that din't get copied over. Any more ideas?
For those elements try using the File>Insert From File command.
Create Templates from Central file.. again for 2010 |
Wed, Sep 30, 2009 at 4:22:28 PM
Can not create local file from Central |
Tue, Mar 6, 2012 at 11:57:26 AM
Transfer Project Standards - View Templates |
Mon, Aug 29, 2011 at 12:03:03 PM
detach from central file |
Wed, May 12, 2010 at 12:28:23 PM
How do i know its a Central File? |
Tue, May 8, 2012 at 8:42:22 AM
