76 Users Online (74 Members):
Forums >> Workflow & Implementation >> Worksets >> Copying Workset Data
1 Posts No Rating |
Hi All We have a situation where a room is laid out using a number of entities in different worksets - external walls, internal walls, equipment etc... We want to create an exact copy of that room - keeping the workset info as assigned, but if you copy (window), the copy all changes to the active workset. I have tried grouping but no effect. Am I missing something or is this a major problem ???
that's right, what ever you copy will move into your current workset. once you copied all you wanted to, right click on an element -->select all instances click properties and move to the workset of your choice.
Copying schedule data |
Fri, Sep 15, 2006 at 12:43:59 AM
Default Workset |
Sun, Sep 25, 2016 at 12:01:18 AM
Saving/unlinking a Workset Without Updating |
Wed, Oct 1, 2008 at 12:24:51 PM
Can't Obtain Permission to edit the Element |
Wed, Nov 5, 2014 at 3:09:01 PM
Pipe visibility / workset problem |
Thu, Dec 22, 2011 at 9:02:36 AM
