Forums >> Revit Building >> Technical Support >> compound walls
Tue, Nov 28, 2006 at 4:59:05 PM | compound walls
dgwarchitect
i am a newbie to revit so if this is a redundant question please direct me to proper post.  i've searched but have not found answer to question.  i am building a new wall, 6" studs, 3" stone on the outside of sheathing, stone will go to the bottom of a stone sill at 3' above the floor levels,  bark siding will be above the stone.  how do i assemble this wall?
thanks dgw
Thu, Jan 11, 2007 at 4:01:59 AM | compound walls
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
First of all create 2 types of wall duplicating an existing type: one with stud and stone, the other one with studs and wood. After that you duplicate a superimpose wall and insert the stone under and the wood above. Draw your wall and create the sil with an extrusion.
-paolo
Real compound walls
Sun, Feb 20, 2005 at 8:26:42 PM
non compound wall acting like compound wall
Mon, Feb 20, 2012 at 2:30:22 PM
Partial Vertical Reveals in Vertically Compound Walls
Thu, Jul 24, 2008 at 1:04:53 PM
Scheduling Compound Walls
Wed, Nov 30, 2005 at 7:05:54 AM
Compound Walls
Thu, Apr 3, 2008 at 4:55:17 PM
Page generation time: 1.5159
