Forums >> Revit Building >> Technical Support >> Column hatch will not go away
Fri, Nov 17, 2006 at 2:57:07 PM | Column hatch will not go away
blake
3 Stars: 2 Votes
I have an architectural column attached to a wall.  They are both in an existing phase.  My walls are generic brick.  I want my columns to be joined with the walls because I want them to read as one in plan and I want them to be brick in elevation.  The problem is when I am in a new phase the wall hatch goes away like I want it to but the column hatch stays.  Is there a way to get around that other than detaching the columns and adding a surface material but also having it showed as a joined element in plan.
Control Hatch Display
Tue, Jan 10, 2012 at 10:26:34 AM
Concrete Hatch Pattern Lineweight Not Consistent
Wed, Jan 13, 2016 at 10:07:52 PM
Column taking on adjacent fill patterns
Tue, Oct 21, 2014 at 3:56:17 PM
column to wall connection [ 1 2 ]
Fri, Apr 8, 2011 at 6:06:29 AM
16
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:04 AM
Page generation time: 0.1351
