Forums >> Revit Building >> Technical Support >> Autocad line weights in REVIT
Wed, Nov 3, 2004 at 11:05:23 AM | Autocad line weights in REVIT
Chirag
What is the best way to see and print an AutoCAD xref drawing from REVIT. Can we match up the lineweights as used in AutoCAD? Thanks Chirag
Wed, Nov 3, 2004 at 1:16:53 PM | RE: Autocad line weights in REVIT
pi_arch
hi, u can very easily change the line weights of the imported dwg in revit. Go to setting in that either u have imported object line weights (4.5 version) or object line weights with an option in that as dwg file (6 version). there u exactly get the dwg file with its imported layers and u can select each one and give them their line weights .
Revit line weights
Wed, May 15, 2013 at 10:49:44 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
Page generation time: 1.8686
