55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Repeating Detail component on a curve
IS it possible? There are many situations where I would like to array an object along a curve. For example to show a curtain (see attached image).
I have done it in the past when I have used autocad by making a block and using the "measure" command. IS there anyway of doing this in Revit?
Check out the augi forums, people have setup adjustable line based detail components that enable an adjustable arc like you show. Generally achieved by a radial array, but broken down in a series of nested families. You can only lock one part of the radial array nest at a time without experiencing issues.
repeating detail that can be stretched |
Mon, Feb 18, 2019 at 4:23:08 PM
Repeating Detail Component for Metal Lath |
Tue, Apr 1, 2008 at 12:59:06 PM
Editing instance of Repeating Component |
Mon, Jan 13, 2014 at 12:12:25 PM
Graphics params in repeating detail |
Tue, Sep 11, 2007 at 8:20:27 AM
Repeating Detail - Snaps don't work |
Tue, Jan 25, 2011 at 9:33:15 AM
Members: | 2000339 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
