536 Users Online (38 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Exporting Linked Revit Files coming in as Blocks
Mon, Oct 16, 2006 at 2:47:07 PM | Exporting Linked Revit Files coming in as Blocks
superelboogie
I am exporting plans to autocad that are duplexes and each side is a linked file. Is there a way to export where the linked files do not come in as blocks. and that they are xrefed like in a regular (no links) file. The blocks cause problems cuz they mess up all the colors of the layers. the layers are named right and show that they should be the right colors, but then theve been overide with a new color. Weird! Any ideas would be greatly appreciated! Ok... so i figured out that i need to set the linked files settings to linked veiw to get the colors to be right.... but i'm still stunped on the xref thing instead of a block Post edited on 2006-10-16 15:55:23
Thu, Aug 14, 2008 at 2:30:28 PM | Exporting Linked Revit Files coming in as Blocks
sbharri2
Having same problem!!! Please help
Fri, Sep 2, 2011 at 9:19:06 AM | Exporting Linked Revit Files coming in as Blocks
mikeinsverige
Any thoughts on this issue? In a large project with many revit links (in lieu of groups) Revit is making a dwg xref for each link. Hundreds! It is crashing now...
Fri, Sep 2, 2011 at 10:16:38 AM | Exporting Linked Revit Files coming in as Blocks
mikeinsverige
So...there is a little option for "xref views on sheets" or something like that. I unchecked it, and it no longer made all my revit links into xrefs. (even though I wasn't exporting sheets, just model views, it worked)
Creating Families
Wed, Sep 24, 2008 at 5:06:16 PM
Using/ Matching a CAD title Block
Wed, Dec 19, 2007 at 2:49:50 PM
Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Mon, Mar 21, 2011 at 3:03:58 PM
New in Autodesk® Revit® Architecture 2011
Mon, Apr 26, 2010 at 2:12:40 AM
some elements are coming exploded while I exporting from revit to autocad
Tue, May 10, 2016 at 3:44:21 PM
Page generation time: 1.4352
