Forums >> Revit Building >> Technical Support >> Wall cappings
Fri, Sep 1, 2006 at 1:10:18 AM | Wall cappings
psymon
psymon Avatar
3.5 Stars: 6 Votes
How does everyone do wall cappings or do they not bother? eg: Typically on parapet walls we do a barge cap. Do people do this as a thin roof and attach the tops of the walls to it or do they do a wall sweep? I have the problem where you have varying wall thicknesses. Especially I have one situation where we have a boxed out lightweight awning about 600mm deep. I just want to put a steel cap over it that falls to the roof. This intersects on the sides with normal double brick walls. Any ideas/best practices?
Sun, Sep 3, 2006 at 11:54:36 PM | RE: Wall cappings
nandini
can u send over a skecth showing what it is that u actually want. i am a little confused about what you want. but going by what u say, wall sweep should work well...dont worry about the wall thickness...just associate the sketch profile to the wall faces.
Wed, Sep 6, 2006 at 8:25:11 AM | RE: Wall cappings
John Algeo
How do you associate a profile to a wall face.
Sloping wall capping
Sat, Oct 17, 2009 at 4:58:30 PM
Ridge Capping?
Fri, Jan 27, 2017 at 6:44:05 AM
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 6:20:51 AM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
Page generation time: 1.9524
