61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> IMPORTING LINETYPES
I am working on a project that is mostly in Revit, but several consultants are working in AutoCAD. I have figured out how to import each of there different .ctb styles with the import_lineweight.txt files. The problem that I have run into is with the site plan. They show a fence line in the .dwg file, that's a line with little circles in it. Well, Revit only shows it as a continues line. I have looked for a fence line in Revit, but I haven't been able to find one. Does anyone have experiance with this kind of problem? Is there a way to get new linetypes into Revit?
ArchWestCY
the best you can do i think is to simulate this type of line as a repeating detail using the component tool
HTH
Post edited on 2006-08-22 15:31:51
Make sure your .ctb is reading the linetype correctly. It maybe asignned a different type in the .ctb.
Complex Linetypes in Revit? |
Mon, Jul 2, 2012 at 1:51:38 PM
DWG Revit export replacing linetypes with erronous linetypes |
Tue, Mar 17, 2015 at 10:07:42 AM
Getting CAD Linetypes into REVIT |
Thu, Jul 24, 2008 at 7:11:10 PM
Linetypes and Phases |
Thu, Dec 1, 2005 at 5:29:34 PM
Custom Linetypes |
Wed, Nov 7, 2007 at 5:53:17 PM
Members: | 1993927 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
