82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Quetsion for Mr Spot
I have used your fixed corner window that I download from revitcity. I need to make a corner door setup where two bi-folds meet at the corner with no mullion. My first problem is that I can't work out how you made the opening. I have tried opening but this only gives you elevation as a choice. Have tried void but this won't cut wall.
My second problem is how to nest existing bifold families into the family?
Thanks in advance Mr Spot or to anyone else.
Post edited on 2006-08-13 23:25:19
Macca Sunshine Coast QLD Australia |
Sorry for the delay. When I login into to Revit City I normally just go to "Today's Posts" otherwise I'll end up spending my whole life here. Send me a PM if you need an answer to a query specifically to me. You need to delete the opening and create it as a void. Then use the cut geometry tool to tell the void to cut the wall. As the existing bi-fold families have openings they can't be nested as you can't have both voids and openings in the same family. Thus you would need to create them as a non-hosted family and nest them or create them all in the one file... HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Door handle not on a door plane |
Wed, Apr 5, 2017 at 11:18:14 PM
litle spot |
Sat, Apr 23, 2005 at 6:38:09 AM
Spot Levels [ 1 2 ] |
Wed, Nov 7, 2012 at 10:49:19 PM
18
Spot Lighting Beam Spread |
Sun, Nov 9, 2008 at 9:20:16 AM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
Members: | 1991937 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
