Forums >> Revit Building >> Technical Support >> Roof Join with Joining roof slope cutback
Sat, Aug 12, 2006 at 5:45:46 PM | Roof Join with Joining roof slope cutback
NewBe
I can't figure this out. I have tried extending and mathing the slope and building a roof patch and joining the geometry. Any assitance would be greatly appreciated. Thanks, Sandra Dee
Sat, Aug 12, 2006 at 9:23:24 PM | RE:
geasa
4.5 Stars: 2 Votes
Can you send us a layout of the final roofyou want so we can figure out what you want to do?
Sat, Aug 12, 2006 at 9:55:04 PM | RE: Roof Join with Joining roof slope cutback
NewBe
I need it to look like the attached JPG but without the lines. Where the higher roof peak joins with the lower, I need it to slope back using the pitch of the lower roof slope.
Sun, Aug 13, 2006 at 2:09:13 PM | RE:
geasa
4.5 Stars: 2 Votes
Your drawing suggest to me a roof like the one in the following enclosed file. Is this your intend? Otherwise, I still need a more explicit drawing from you. Ciao
Post edited on 2006-08-13 14:09:30
Thu, Aug 17, 2006 at 6:18:28 PM | RE: Roof Join with Joining roof slope cutback
NewBe
Actually the roof is higher like attached. Thanks.
Thu, Aug 17, 2006 at 6:42:26 PM | RE: Roof Join with Joining roof slope cutback
CJCoon
I would simply suggest you set the ridge height for both roofs at the same elevation. Is there a reason why the roof on the left needs to be higher then the roof on the right? (Going by your latest attachment) Come to think of it. When you draw the outline of the roof on the left, make sure that it is offset from the ridge of the roof on the right. An 8th of an inch should be sufficient. Is this what your looking for?(attached) Kune
RHL Design Group Inc.
Thu, Aug 17, 2006 at 6:44:33 PM | RE: Roof Join with Joining roof slope cutback
CJCoon
jpg instead of rvt Kune
Thu, Aug 17, 2006 at 7:24:02 PM | RE: Roof Join with Joining roof slope cutback
NewBe
The reason can be describe with one word "Remodel". The higher roof is going to be an open beam ceiling attaching to the existing lesser pitched roof. I have seen rendered images similiar to what I'm doing, I just can't figure out the steps to achieve the effect.
Thu, Aug 17, 2006 at 8:09:04 PM | RE: Roof Join with Joining roof slope cutback
NewBe
Finally! The Newbie thing is going to kill me. Here's the file so that hopefully no other newbies have to struggle. Thanks to all of those that helped.
Tue, Jun 26, 2012 at 6:29:25 PM | Roof Join with Joining roof slope cutback
ffdraws
I'm sure you're tired of such dumb questions but here goes again.  I looked at your 3D roof model of uneven roof heights intersecting and that looks great but how do you do it.  Having the model doesn't explain the steps to me.  Is there a video I can view to better understand this seemingly simple roof intersection. I would have thought that Revit would do this automatically since it happens in the real world all the time.
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
How to join 2 gable roof?
Mon, Sep 28, 2009 at 9:16:37 PM
roof joining
Wed, Feb 25, 2009 at 2:22:00 PM
Joining a conical roof to a gable roof or other rectangular roof
Tue, May 28, 2013 at 9:29:25 AM
Roof join/void form problem
Wed, Aug 14, 2024 at 4:51:22 PM
Page generation time: 0.2547
