2 Users Online (0 Members):
Forums >> Revit Building >> Technical Support >> Lines
Is it just me or is Revit's way of showing general linework pretty obtuse?
Why can't we just draw lines, be they detail or model and then choose thickness, type, end, etc.?
Post edited on 2006-08-10 13:59:59
You can!
When "drawing" a line be sure to select the "type" from the type drop-down box (upper left of screen).
If the line already exists, select it and then change it's type. Tip:You cannot change detail lines to model lines and vice versa.
You can add and modify line definitions by going to Settings>Line Styles (be sure to expand the +)
HTH
Tom
You can!
HTH
Tom
Thanks Tom,
I knew that but somehow it seems a really awkward way to do things - What I need is a way to take a line and just alter its weight, linetype, etc without having to create another line style - our drawings are cluttered with all sorts of line styles.
Then there's the inability to have square/mitered ends to lines...
Post edited on 2006-08-10 16:40:55
Can you convert model lines to detail lines? |
Wed, Mar 31, 2010 at 12:45:23 PM
Model Lines to Detail Lines??? |
Sun, Aug 31, 2008 at 9:24:50 PM
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
Lines plotting half toned |
Fri, Jun 15, 2012 at 10:42:01 AM
Possible to place contour lines to toposurface instead of points? |
Fri, Jun 1, 2018 at 2:57:52 PM
