Forums >> Revit Building >> Technical Support >> Miter joints?
Tue, Jul 25, 2006 at 7:49:50 PM | Miter joints?
iREV
3.5 Stars: 3 Votes
Anybody know how to miter a channel? I am building a canopy could there be a better way?
Tue, Jul 25, 2006 at 9:57:43 PM | RE: Miter joints?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Channel and canopy are both very arbitrary words. Could you please be more specific on what exactly you are trying to do. Then we'll be able to help out more effectively.
Wed, Jul 26, 2006 at 9:20:47 AM | RE: Miter joints?
jterrell
3 Stars: 5 Votes
Revit structure can miter structural elements using a reference plane - extremely useful. I'm not sure if there is a way to accomplish this in Revit Building or not. I've tried before and finally gave up. I think Revit should be able to cut any type of family with void extrusions - ala ArchiCAD.
Wed, Jul 26, 2006 at 12:33:35 PM | RE: Miter joints?
iREV
3.5 Stars: 3 Votes
The canopy is hosted by a wall and comes to a 90 degree intersect with another canopy. So the Canopy will in an L shape. Also there is a radius wall that I would like to connect a canopy to as well is this possible? I would like to have all three canopies connect.
Fri, Jul 28, 2006 at 12:04:10 AM | RE: Miter joints?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Would a fascia be useful in this situation? As these mitre automatically. Remember a fascia can be any loaded profile and can be offset from a roof edge if needed. Otherwise an in-place familiy sweep using a loaded family profile... If these are repeated then perhaps and external family.
Problem with roofs and parapet walls
Thu, Mar 29, 2007 at 4:55:44 PM
where is fascia miter?
Thu, Sep 15, 2005 at 10:52:36 PM
vertical joints in hosted wall sweep?
Mon, Aug 13, 2007 at 3:37:15 PM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Concrete control joints
Thu, Mar 31, 2016 at 1:52:27 PM
11
Page generation time: 1.0747
