Forums >> Revit Building >> Technical Support >> windows offset from face of wall
Fri, Jul 14, 2006 at 11:11:18 AM | windows offset from face of wall
gdoorn
1 Stars: 1 Votes
i am trying to model some windows that are not in the same plane of the wall they reside in. so far the only way i have been successful is by cutting a hole in what should be the host wall, adding a new custom width wall in front of it and dropping the window into that wall. is this the best way to achieve a window offset say 6" from the wall? this issue is complicated when i have a full stud furring out the plaster finish, above a CMU wall. and the window is projecting 4-6" out beyond the face of finish. so the window is 8-10" from the face of the bearing wall.
Fri, Jul 14, 2006 at 5:03:24 PM | RE: windows offset from face of wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I make it a habit with all window families i create of giving them an offset parameter to enable me to position the window in the wall as i see fit. So its probably best to modify the family if this is something you typically do. I can't suggest any workarounds for this as you'll find most of them will end up being more trouble than they're worth when changes start occuring. HTH.
Offset face of Mass = possible?
Tue, Jan 21, 2014 at 2:06:18 PM
Help Needed To Split Face and Add Windows
Fri, Jun 26, 2009 at 5:36:49 PM
Aligning Face of Curtainwall w/ Face of Wall
Tue, Mar 11, 2008 at 3:01:57 PM
painting split walls with windows
Thu, Nov 15, 2012 at 3:17:04 PM
Leaning windows? (Windows in leaning walls?)
Fri, Aug 20, 2010 at 8:15:17 AM
Page generation time: 0.7236
