353 Users Online (25 Members): Show Users Online - Most ever was 712 - Sat, Aug 8, 2026 at 7:11:41 PM
Forums >> Revit Building >> Technical Support >> Curtain wall glass in front of mullion
Wed, Sep 24, 2025 at 5:54:30 PM | Curtain wall glass in front of mullion
Warchitect
4 Stars: 5 Votes
So Im trying to create a glass wall for my project based on the spec given to me. See Screen Shot for that. but basically the mullions are sort of behing the glazing, and the glazing panel overlaps them, such that there is only a small seam between the glazing edges, and that is supported by the mullions and such behing it mounted on to a slab... the seam is so small that i dont need to actually make a mullion for that, as it would be invisible on the scale of a hi-rise. but when I get down to making the curtain wall, is there a way to get the mullion behind that glazing, such that it doesn't make the glazing panel adjust to the "behind / hidden" larger mullion, but instead overlaps it? again the detail image should help.
I figure ill just make the glass wall with seams and do the support mullions after (?)
Cant load Curtain Wall Door
Wed, Oct 26, 2011 at 3:41:44 PM
Curtain windows/doors
Fri, Dec 12, 2008 at 6:59:44 AM
connecting slope glaze roof to curtain walls Part II
Sat, Jul 10, 2010 at 2:27:20 PM
Curtain Wall - Glass and Mullion Detail
Tue, Oct 2, 2007 at 4:19:30 PM
Curtain wall by line
Sat, Feb 13, 2010 at 6:47:22 AM
Page generation time: 0.4114
