21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Creating a parameter on a window
Hi,
I'm fairly new to Revit and I wondered if anyone can help me.
I'm currently adding windows into my project and I noticed that the width is the same internally as it is externally.
At the moment you can only edit the width which controls the width for the entire window. Is there a way to create a new parameter to control the width internally. As majority of the time the internal width is small due to plasterboard etc.
Apologies if I havent explained this very well!
Many thanks
Sorry, your question is not clear enough.
For most window families, width is the opening width that the window goes into . It excludes any trim. There is no inside/outside.
The depth of the widow may or may not be controlable, depending on the window.
window inset parameter for the Revit 2017 OOTB windows |
Thu, Mar 22, 2018 at 8:55:22 AM
creating window with glass area constraint |
Fri, Apr 20, 2012 at 3:58:44 PM
Creating Uneditable Parameter? |
Wed, Mar 12, 2014 at 12:50:31 PM
Creating Window Sills |
Tue, Jul 3, 2012 at 1:26:39 PM
Legends for creating window or door schedules |
Thu, May 29, 2008 at 11:18:05 AM
