151 Users Online (148 Members):
Forums >> Revit Building >> Technical Support >> disappearing text
ok...so maybe this is just a case of Murphey's Law striking, but we were wrapping up our Plan Check set here in my office today, and realized that sometime yesterday, we lost a bunch of text throughout the project. our ADA sheets were wiped out completely, and loose text in plans, sections & elevations also disappeared. it wasnt a visibility issue or anything. we had to go back and redo the text in the 11th hour
Has anyone else run into this? i dont think anyone changed anything. it was a project wide issue. has me baffled.
All i can imagine is someone has used the select all instances command thinking it was a per view command...
Then hit the delete key, unknowingly deleting all the text of that type in the project...
keynotes by sheet text randomly disappearing |
Mon, Oct 1, 2012 at 10:58:15 AM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009) |
Thu, Feb 12, 2009 at 1:29:29 PM
Problems with adding text to dimension lines. |
Fri, May 29, 2009 at 8:48:43 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Disappearing Callouts |
Thu, Feb 14, 2008 at 11:36:27 AM
Members: | 1995718 | Objects: | 22885 | Forum Posts: | 152175 | Job Listings: | 3 |
