Forums >> Revit Building >> Technical Support >> Hello to all the experts out there..need help!!
Thu, Dec 17, 2020 at 10:02:58 PM | Hello to all the quantity takeoff experts out there..need help!!
nitinraj97549
Hey Guys, i am new on revit and currently trying to model a project in revit. Its a multistorey building with G+1 parking and another 8 floors residential, till now i have placed beams, slabs till 2nd floor (i.e first residential floor) and placed all the walls. My main goal is to abstract the accurate quantities of the finishing materials (that includes tiles,granites, paints, electrical, plumbing etc). Now, after placing walls i am creating a door/window family to place on walls. So my question is... Can i add Granite as a door/window framing material instead of wood and later take the quantity of the granite in SquareMeters??. Also, Can i add Veneer sheets over the flush door panel, wood frame and later take the quantity takeoff in SquareMeters??
Edited on: Thu, Dec 17, 2020 at 10:09:08 PM
Fri, Dec 18, 2020 at 7:35:59 AM | Hello to all the experts out there..need help!!
What you are asking for is way too complicated for a begineer and some of it can not be done at all.
  • If you model correctly, you can take off wall tile and floor tile areas because you would model those as an applied element to the substrate.
  • Paint is usually never modeled so typically to get those areas, yould would use rooms and some math.
  • Electrical & plumbing would need to be modeled by someone that works in those fields.
  • Door frame volumes can not probably be extracted but the number and type of each frame can easily be produced to apply a known volume to.  The same for the door facing.
What are some common problems that architects or archviz experts face?
Sun, Sep 11, 2011 at 7:37:38 AM
Help With Roof
Thu, Jun 18, 2020 at 9:19:15 PM
How to make architectural elements of elevations?
Fri, Jun 5, 2020 at 3:51:26 AM
Plug-ins?
Fri, May 8, 2015 at 5:35:33 AM
properties / project browser 2014
Mon, Feb 23, 2015 at 9:21:05 AM
Page generation time: 0.0137
