Forums >> Revit Building >> Technical Support >> Imported xml file doens't appear
Wed, May 20, 2020 at 9:15:15 AM | Imported xml file doens't appear
Fryingpanman
Hi folks,
Using the Site Designer tab (Revit version 2020), I import an XML file, which is a toposurface. Once imported, it doesn't show in any view (including 3D views). Phasing is correct too.
Any ideas?
Thanks in advance...
Wed, May 20, 2020 at 9:31:14 AM | Imported xml file doens't appear
I have never used an xml file but for other imports, the problem is often where the import is elevation wise in the Revit file.   Usually when this happens, the file is way above the Revit model.
Exported Keyboard Shortcut file is .xml format - can't open in Excel
Fri, Jan 13, 2012 at 11:41:37 AM
import xml files
Wed, Jan 5, 2011 at 10:40:41 PM
Revit Families with XML files
Thu, Nov 8, 2012 at 7:00:31 AM
xml files for plumbing and duct
Mon, Feb 12, 2007 at 11:59:36 AM
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
Page generation time: 0.8857
