6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Text issue
When I use text, instead of left to right the program writes from top to bottom. It happens every second instance. It does not happen if I double click at the start of the text (which results in a blue curser). Any idea how to prevent that?
If you are using a text box that is too narrow, the text might stack like that. If I remember, Revit sometimes saves the last text box shape and defaults to that.
Thank you. I think it solved the issue.
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Faint Text Issue |
Tue, Aug 21, 2007 at 7:01:52 PM
Text Scrambling Issue with Revit 2015 LT on Windows 8.1 |
Sat, Jun 13, 2015 at 11:17:05 AM
Rotating Family Text |
Wed, May 7, 2014 at 5:04:06 PM
LIMIT TO TEXT CHARACTERS IN A TEXT BOX (2019) |
Tue, Nov 19, 2019 at 3:29:14 PM
