Forums >> Revit Building >> Technical Support >> Create a fancy door panel.
Fri, Jul 27, 2018 at 11:21:04 AM | Create a fancy door panel.
1bchristian
Revit 2017 - I need to create some fancy door panels and cabinet doors for a project. I have research but have not found anything that I can read or will help create one. Does anyone have any suggestions where to go to find some instructions. - Thanks Byron
Fri, Jul 27, 2018 at 11:33:55 AM | Create a fancy door panel.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You should probably start with the ootb casework and just modify the panels. If it's just for elevations you can do it with detail lines. If you want to see it all in full 3D then you'll need to make some extrusions and maybe some sweeps. Learn it all from www.CADclips.com
System Panel Door
Wed, Sep 29, 2010 at 9:55:55 AM
6 panel bifold door
Tue, Jan 26, 2010 at 2:03:12 AM
Door Panel Material Parameter Selection
Wed, Nov 19, 2008 at 4:34:12 PM
curtain panel door not reading completely in schedule
Thu, Jun 30, 2011 at 1:56:58 PM
Nested 3d door panel parametric swing and the width problem
Tue, May 21, 2013 at 7:58:01 AM
11
Page generation time: 0.5913
