9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Exporting to DWF with Phase Filters.
16 Posts No Rating |
Using REVIT 2017. I have models created with "existing" and "New" phases set up. When I export to DWF, some of the objects that are on "existing" phase are not showing up on the dwf until i zoom in closer. It's like Design Review isn't regenerating everything? This only happens on models using Phasing. Is this a graphical issue and is there anyway to correct this? Also, the "Existing " Phase is set to Halftone. But, other linework that is halftone has always worked before.... Not a big deal, but annoying. Any thoughts?
try pdf?
I imagine it is a 'double whammy'... You set exiting to grey and the dwf filters that as well. What happens if you remove your grey filter?
3D DWF Exporting in 9.1 |
Wed, Feb 7, 2007 at 3:39:28 AM
3d DWF export |
Wed, Apr 4, 2007 at 10:32:34 AM
Walls layers + phase filters display problem |
Wed, Dec 21, 2005 at 5:40:14 PM
material patterns rotate when exporting to a DWF revit 2015 |
Thu, Jan 22, 2015 at 12:41:59 PM
phase filters |
Thu, Mar 27, 2008 at 11:07:54 AM
