Forums >> Revit Building >> Technical Support >> Revit 2009 rendering
Mon, Jan 15, 2018 at 12:50:01 PM | Revit 2009 rendering
Chudivitalis
I use revit 2009 and would like to know why after rendering, material objects like trees, cars and entourage does not render? Even when I use revit 2012 to render, no material objects get rendered. The shrubs will disappear. ..... Ude VC
Sun, Jan 21, 2018 at 6:01:09 AM | Revit 2009 rendering
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Has seamless rendering material textures at the correct scale been assigned to these objects?Is your GPU powerful enough for the tasK?
Why aren't you using Enscape3D?
Sun, Jan 21, 2018 at 7:56:13 AM | Revit 2009 rendering
We used 2009 for over a year and never had any problems so your problem is one of the following:
  1. Program not updated for that issue
  2. Not using RPC objects
  3. Incorrect view settings or filters
  4. Your system / program problems
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:24:59 AM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:18 AM
Rendering in 2009
Wed, Jun 11, 2008 at 3:18:08 PM
Page generation time: 2.7020
