Forums >> Revit Building >> Technical Support >> I can't print in color the ''color fill legend''.
Wed, Aug 16, 2017 at 4:15:25 AM | I can't print in color the ''color fill legend'' on a Sheet.
giovanni22
Hi.
Can anybody help me with a problem I have?
I print the entire sheet in color except for the ''color fill legend''  which insist at, printing out only in shades of grey .
The same happens also if trying to print only the ''visible window''.
Is there a regulation that I maybe didn't saw?
I made also a new project only with a few rooms and  ''color fill legend'' and still is printed (the  ''color fill legend'') in black and white when everything else in color.
Thank you.
Edited on: Wed, Aug 16, 2017 at 5:33:37 AM
Edited on: Wed, Aug 16, 2017 at 5:35:33 AM
Edited on: Wed, Aug 16, 2017 at 6:50:30 AM
Edited on: Wed, Aug 16, 2017 at 7:44:42 AM
Edited on: Wed, Aug 16, 2017 at 7:46:42 AM
Edited on: Wed, Aug 16, 2017 at 8:14:41 AM
Edited on: Wed, Aug 16, 2017 at 12:06:20 PM
Edited on: Wed, Aug 16, 2017 at 12:10:29 PM
Edited on: Wed, Aug 16, 2017 at 1:24:13 PM
Wed, Aug 16, 2017 at 1:26:16 PM | I can't print in color the ''color fill legend''.
giovanni22
Here is a photo of the printed file
Wed, Aug 16, 2017 at 2:30:37 PM | I can't print in color the ''color fill legend''.
The color fill legend is actually in the plan view - correct?  So when you view just the plan, the color fill legend is colored?
Thu, Aug 17, 2017 at 2:49:13 AM | I can't print in color the ''color fill legend''.
giovanni22
Hi.
Yes. On screen it is in color but when I print it was in this situation, with only the ''color fill legend'' black and white.
BUT!  Crying I write from the office). I changed printer (on network) with another which is much near and now is everything ok.
I did't printed the same exact plan, but another, but I don't think it matters.
It must be the long distance (15 meters) with the first printer that caused the problem.
I can't give another explanation.
Edited on: Thu, Aug 17, 2017 at 5:55:52 AM
'Surface Pattern' and corresponding 'Region Fill' appear differently.
Fri, May 17, 2013 at 9:11:54 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
Fri, Nov 22, 2019 at 12:27:55 PM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 0.6421
