Forums >> Revit Building >> Technical Support >> Slopped Wall on Site Topography
Tue, Aug 1, 2017 at 3:53:16 PM | Slopped Wall on Site Topography
alihusnain8395
Hi
I am working on Revit Site topography , Site terrain has lots of levels. I need to make many walls only 300mm above the ground level and this 300mm need to same abovegroundand slopes,
If I create normal wall, if gives me 300mm from one end but 700mm from the other end, I know i can edit profile of the wall to change shape but ssite terrain is bit complicated and isnt and ideal solution
Any Help?
Ali
Wed, Aug 2, 2017 at 1:33:30 PM | Slopped Wall on Site Topography
I wonder if Revit 2018's host railings to topo surface could be modified to work for you.
SLOPPED FLOOR
Wed, Jul 23, 2008 at 12:06:36 PM
SLOPPED BEAMS
Thu, Jan 16, 2014 at 1:00:32 PM
Importing site plan to do a 3D topography
Sun, Jan 29, 2006 at 11:53:50 PM
slopped pad
Fri, Jun 23, 2006 at 7:23:16 AM
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Page generation time: 0.9150
