Forums >> Revit Building >> Technical Support >> Orientation Confussion...
Thu, Apr 20, 2017 at 8:36:41 AM | Orientation Confussion...
Beard0
My Revit model is confusing when looking at the orientation, and trying to figure out which way it is facing. In plan view, the north face of my building is facing up, but looking in 3D view the north face is actually facing south, messing with the sun angles. This wouldn't usually be a problem because I should just be able to rotate the building to the correct orientation, but when I try to do that the 3D camera views I have already set up do not go with it. The question I cant figure out is whether there is a way to rotate the camera views along with the rest of the building, or if there is a way to reset which direction the ViewCube in the top right corner faces.
Thu, Apr 20, 2017 at 10:22:49 AM | Orientation Confussion...
Do you understand Project North and True North.  Read those links.
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
add orientation to window schedule
Mon, Feb 3, 2014 at 7:23:49 AM
2x4 ceiling grid orientation
Mon, Aug 7, 2006 at 8:53:22 AM
north orientation
Fri, Dec 16, 2005 at 5:49:04 PM
Functionality Bugs
Workflow & Implementation >> Chameleon
Mon, Oct 15, 2012 at 5:55:48 AM
Page generation time: 0.1074
