Forums >> Revit Building >> Technical Support >> individual 3 D modellview
Tue, May 23, 2006 at 4:22:25 AM | individual 3 D modellview
Unknown
When i change into the 3 D modellview i like to see only one part of my body modell, but i can only chose the whole bodymodell in the viewoptions. Is it possible to make a individual view including only one part of the bodymodell??? Post edited on 2006-05-23 04:22:56
Tue, May 23, 2006 at 4:35:19 AM | RE: individual 3 D modellview
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use scope boxes... Simply turn them on in your 3d view and adjust there extents. You can also orient your 3D view to have the same extents of any plan/section etc... This is a quick way to change you scope box without the need for drag its grips. HTH.
Converting Walkthrough to Individual Views
Tue, Feb 7, 2012 at 4:40:37 PM
Half tone individual wall components
Wed, May 27, 2015 at 9:40:19 AM
Removing individual vindowsegments from a curtainwall?
Wed, Apr 22, 2009 at 8:20:08 AM
Remove individual holes from cellular beams
Tue, Jun 17, 2008 at 1:02:33 PM
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
Page generation time: 0.5153
