Forums >> Revit Building >> Technical Support >> Ceiling with multiple slopes.
Thu, Dec 15, 2016 at 5:46:27 PM | Ceiling with multiple slopes.
TedMiller0111
Has anyone found a workaround for this??  Slopearrow only gives one direction...I need two.
Using v2017
Thank you in advance
Thu, Dec 15, 2016 at 6:14:25 PM | Ceiling with multiple slopes.
What do you mean two?  Have you ever used diagonal?
Fri, Dec 16, 2016 at 12:07:06 PM | Ceiling with multiple slopes.
TedMiller0111
By two I mean: I have slope front-to-back, and a slope side-to-side.....basically.
What is diagnol?
Fri, Dec 16, 2016 at 1:18:01 PM | Ceiling with multiple slopes.
A typical ceiling is a plane.   It can slope front to back, side to side or one corner to a diagonal corner.   In all cases, the plane is still one, flat plane.  It can not be warped. So for a ceiling that slopes in two directions from one point, you use a diagonal slope arrow.
If two edges are held, then you need to divide the ceiling into two planes each with its own slope arrow.
Auditorium Floor Multiple Slopes
Fri, Feb 22, 2008 at 12:31:24 PM
Multiple sloping slab on grade
Wed, Sep 28, 2005 at 11:20:27 PM
Splitting a ceiling
Fri, Nov 11, 2011 at 12:34:50 PM
Multiple Ceiling Tags
Mon, Jul 21, 2008 at 5:25:13 PM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
Page generation time: 0.2427
