Forums >> Revit Building >> Technical Support >> Revit Stone Veneer
Mon, Nov 14, 2016 at 3:09:22 PM | Revit Stone Veneer
plyrockie59
Alright so I have been working in revit for a little while but I am still perplexed with the image repetition. I am working on a project with stone veneer, I have made the wall accordingly but the problem is that the image is repeating and the client has noticed and asked if there is any way to remove that. I am honestly not sure how to do that. I know how it works in the sense that for rendering purposes it uses an image to render it to make it look life like which is what I am going for but I am unable to figure out how to get it so that it doesn't look like the image is repeating. Any help on this matter would be greatly appreciated. Thank You.
Mon, Nov 14, 2016 at 3:42:08 PM | Revit Stone Veneer
On 2D drawings, our materials use a fill pattern.   For rendered views, the material is created by using a repeated pattern that you assign (or someone who created it).  It is up to you to make sure that pattern image is sized correctly so it repeats without line variation.  This iimage needs to be normal to the surface without any perspective.
Depending on the image used though, you can get pattern breaks because of color variation.   Again, it is up to you to create your material using the best image you can find that will not do this.  Sometimes you have to photoshop that material to remove this visual difference at the pattern edges.
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Stone Veneer and Framing Plan
Wed, Nov 14, 2007 at 12:12:22 PM
Inserting stone into brick veneer
Mon, Nov 13, 2006 at 9:58:31 PM
whats the best way to show stone veneer on your rendering
Fri, Mar 5, 2004 at 9:03:10 PM
Page generation time: 1.2793
