Forums >> Revit Building >> Technical Support >> Need to export in place mass with divided surface to solid AutoCAD geometry
Mon, Oct 31, 2016 at 7:31:09 PM | Need to export in place mass with divided surface to solid AutoCAD geometry
54Mark77
Hello all,
As the subject indicates, I have an in place mass in the project environment with a divded surface (mesh). I need to export the geometry as a solid into AutoCAD. Any feedback?
Edited on: Mon, Oct 31, 2016 at 7:32:37 PM
Tue, Nov 1, 2016 at 8:13:56 AM | Need to export in place mass with divided surface to solid AutoCAD geometry
Have you tried?
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-CE5C1481-40BE-4503-A55C-25B0BC0F817B
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:15:59 AM
In-Place Mass Family with divided surfaces can have seperate worksets?
Tue, Feb 2, 2016 at 7:18:26 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
How to delete some in-place mass divided surface triangular curtain panel?
Sun, Jun 9, 2013 at 1:50:48 PM
Page generation time: 0.6896
