85 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Instancing elements
Tue, May 16, 2006 at 8:13:05 AM | Instancing elements
Steiner
Hello there... I need to know, is it possible to instance elements, so that altering 1 will affect the other as well? If so, how is it done?
Tue, May 16, 2006 at 11:22:32 AM | RE: Instancing elements
arccodex1
3 Stars: 1 Votes
You can group elements and copy the group from place to place. Edit one group and all the instances update.
Tue, May 16, 2006 at 5:20:35 PM | RE: Instancing elements
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It might help to know what sort of elements you are talking about...? As groups are the way to go if you are talking about how some elements interact with others. And parametric families and types would ne the way to go if you are talking about singular elements. HTH.
Wed, May 17, 2006 at 7:22:17 AM | RE: Instancing elements
Steiner
Well, to be more specific, I want to implement a north arrow, and I want it to instance on all of my floor plans. e.g. when I rotate my ground floor arrow, I want my 1st floor arrow to rotate as well.
Wed, May 17, 2006 at 8:25:49 AM | RE: Instancing elements
latemore
latemore Avatar
3 Stars: 2 Votes
mr spot has answered this -but i'll try explaining the way i think i'd do it try grouping your north arrow, even though it is just one element. then copy/paste aligned/same place on all your sheets (will not take long). then you can edit that group anywhere and north will be reflected on all sheets. i might try this myself actually!
Thu, May 18, 2006 at 1:53:34 AM | RE: Instancing elements
Steiner
Unfortunately, I haven't been able to get this to work... I've created my North Arrow from a bunch of medium lines, then I grouped them all into 1 group. Afterwards I copied to clipboard, then pasted "Same Place" on the above floor. Finally, I tried rotating the lower floor group, realizing it only affected that group alone, leaving the copied one untouched.. What did I do wrong?
Thu, May 18, 2006 at 2:17:34 AM | RE: Instancing elements
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Dont' group it... Create it as a family with a parametric angle. Then place in all views and set the angle once per type... That way you can easily change it once and have it change in all views... HTH.
Thu, May 18, 2006 at 2:27:08 AM | RE: Instancing elements
Steiner
Alright I shall try that thank you Smile
Thu, May 18, 2006 at 3:33:01 AM | RE: Instancing elements
Steiner
Well Mr. Spot my friend, I created that North Arrow as a new family, added an angle parameter under family types, but I'm assuming there's a way of linking that angle to the actual north arrow.. since so far changing the angle does nothing to the arrow... How can I make it affect the arrow?
Thu, May 18, 2006 at 2:53:42 PM | RE: Instancing elements
arccodex1
3 Stars: 1 Votes
You have to select the group... then Edit Group... then rotate the elements while in the editing mode. You can't just rotate the whole group and expect the others to rotate too. Post edited on 2006-05-18 16:14:59
Thu, May 18, 2006 at 5:25:56 PM | RE: Instancing elements
#11
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting Steiner
"Well Mr. Spot my friend, I created that North Arrow as a new family, added an angle parameter under family types, but I'm assuming there's a way of linking that angle to the actual north arrow.. since so far changing the angle does nothing to the arrow... How can I make it affect the arrow?"
I'd post an example but i don't have one with me at the moment.
What you need to do is a create the north arrow annotation symbol. Load that into another blank annotation symbol.
Place it and rotate it (making sure to centre it on the reference planes intersection), and add a angle dimension to it then link this angle dimension to the parameter.
Now reload this into the project and you'll have an adjustable north pointer.
Wed, Oct 31, 2007 at 1:11:24 PM | Mr Spot
#12
JFosterIII
JFosterIII Avatar
Quoting Mr Spot from 2006-05-18 17:25:56
What you need to do is a create the north arrow annotation symbol. Load that into another blank annotation symbol.Place it and rotate it (making sure to centre it on the reference planes intersection), and add a angle dimension to it then link this angle dimension to the parameter.Now reload this into the project and you'll have an adjustable north pointer."
How do you link the angle dimension to the parameter? I'm quite new to this and I can't seem to find anything that describes this to any degree.
Thu, Nov 1, 2007 at 5:32:01 PM | Instancing elements
#13
latemore
latemore Avatar
3 Stars: 2 Votes
in answer to your questions, i have followed mr spot's advice and achieved a north point that is rotatable, with a type parameter. ie change its element angle property and every instance of it in the project changes.  i have uploaded it so you can test it.
Fri, Nov 2, 2007 at 9:00:07 AM | Instancing elements
#14
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this link also
http://www.revitcity.com/forums.php?action=viewthread&thread_id=9182
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Nov 3, 2007 at 6:37:34 AM | Instancing elements
#15
IDN101
2.5 Stars: 3 Votes
When you create any family, you can associate a dimension with a parameter.
First create the dimension. Then select it. Then choose "Add Parameter" from the Label box, on the Options Bar.
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Revit and instancing
Fri, May 2, 2008 at 2:46:05 PM
Cleaning Up Design Option Elements with Main Model Elements
Wed, Jun 17, 2015 at 1:38:27 PM
select elements on current level only - revit 2014
Tue, Jul 23, 2013 at 7:52:33 AM
Receiving "Can't keep elements joined" message when joining 3 family elements
Tue, Apr 21, 2015 at 11:26:44 AM
Newbie - Need help with mass elements
Mon, Feb 8, 2010 at 1:11:14 PM
Page generation time: 0.4502
