Forums >> Revit Building >> Tips & Tricks >> Stairs
Tue, May 16, 2006 at 2:52:44 AM | Stairs
taeki008
Hi there! Im a new REVIT user...can you help me how im gonna make this stair from my Aurocad here in REVIT? tnx
Wed, May 31, 2006 at 4:19:17 PM | RE: Stairs
quiller
quiller Avatar
2.5 Stars: 3 Votes
I'm assuming you can first create a switch back stair. If not go to the Revit download site and look for the stair sampler. (Click Load and go to Web Library and look for the above). After you create your stair then you can edit the boundries (green lines on each side of stair), and make sure you rejoin the riser to the boundries. The railing can also be created to loop back, agian look in the (this time) railing sampler for ideas.
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 0.0508
