Forums >> Revit Building >> Technical Support >> saving a shaded line view as JPEG
Sun, Apr 23, 2006 at 1:06:09 AM | saving a shaded line view as JPEG
vector23
vector23 Avatar
2 Stars: 16 Votes
when you print a shaded line view the lines come out straight.. but when you export that view as an image the jagged lines go with it.. how can you save a view as a JPEG and get the lines straight?
Sun, Apr 23, 2006 at 2:48:18 PM | RE: saving a shaded line view as JPEG
coreed
coreed Avatar
4 Stars: 16 Votes
i would imagine that the reason the line is jagged because you are converting a vector image to a raster image. Raster images consist of pixels and lines that are on angles tend to read somewhat jagged depending on the resolution (dots per inch) of the file. You can try and lessen this effect by increasing the resolution and decreasing the x and y size of the image when exporting the image. you could end up with some very large files depending on the resolution and the size of the files Don't quote me on this though HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Apr 23, 2006 at 4:38:14 PM | RE: saving a shaded line view as JPEG
vector23
vector23 Avatar
2 Stars: 16 Votes
ok i thought i probly didn't explain enough detail of what i'm talking about.. notice any 3D view on your screen and you will see that the lines are not straight.. some of the lines are either rough or jagged.. go to file>export<image and save it as a jpeg..when you open that image (preferably in paint) it will look exactly like the 3D view you had in revit.. now go back to that view in revit and print it.. in print setup before you print it set it to presentation or high and print it and then compare the jpeg to the print and notice the print has no jagged or rough edges.. getting those straight lines as a jpeg like a print could have something to do with "print to file" but i don't know how that works.. when i do select print to file it saves the print as a "PRN" file but how do i convert that to a jpeg that looks as good as the print quality? thanks very much for your help
Modelling terrain Revit imported from AutoCad
Thu, Oct 20, 2011 at 10:56:40 AM
3D PDF and PRC supports the following data
Wed, Dec 5, 2012 at 4:05:46 PM
schedule - item count
Fri, Oct 31, 2008 at 12:37:15 PM
RevDev Studios - RevEx and RevXL - Spreadsheet plugins for Revit
Tue, Feb 28, 2017 at 7:32:28 AM
I Can't use RPC content in Revit Architecture 2011
Tue, May 4, 2010 at 10:39:50 AM
Page generation time: 1.2991
