Forums >> Revit Building >> Technical Support >> create a custom fill pattern
0 Posts No Rating |
I scaled the pattern down and it is the correct shape just not the correct size. There are two numbers in the formula that are over 2,000 - all of the other numbers seem to match up with the intended size. These are the numbers that are causing the problem it seems.
0 Posts No Rating |
yes that looks pretty spot on. Attached is a screen capture of my Revit model where I drew model lines for the time being. I really appreciate your time. If you can't get to it till Monday that is cool.
can you make it super easy for me and upload a cad file with it the correct size
thanks.
0 Posts No Rating |
Attached is an updated pattern with the dimensions a bit tighter. I created one block with the four rectangles on the sides.
0 Posts No Rating |
So the thread wouldn't let me attach the file to my last post =-/ - maybe I have posted too much stuff LOL. The dwg file that I uploaded earlier is the correct size. Feel free to copy the rectangles around the ends to create the full pattern repeat if this is what needs to be done to run the pattern converter. Thank you so much.
The pattern seems to exceed the revit built in limits. I'm not sure how to get around the problem.
I dont have hatchkit for revit, only autocad, maybe someone else can solve the problem or has an idea.
This hatch pattern (i recreated it) lays out perfectly, and is centered.
I can import it into revit without the angled lines. Those are the problem lines.
*CustomPlankCeiling,DXF Entity Section
;%TYPE=MODEL
127.284894937,30,3,2260.84499644,-1.9753652155,39.601,-2694.0707067 <--- problem line
52.7151050628,6,40.5,2260.84499644,1.9753652155,39.601,-2694.0707067 <--- problem line
-52.7151050628,42,72,2260.84499644,-1.9753652155,39.601,-2694.0707067 <--- problem line
-127.284894937,66,34.5,2260.84499644,1.9753652155,39.601,-2694.0707067 <--- problem line
90,42,0,0,-72,3,-72
180,42,3,0,75,12,-60
-90,30,3,0,-72,3,-72
0,0,34.5,0,-75,6,-66
90,6,34.5,0,-72,6,-69
180,6,40.5,0,75,6,-66
180,72,40.5,0,75,6,-66
-90,66,40.5,0,-72,6,-69
0,66,34.5,0,-75,6,-66
-90,30,75,0,-72,3,-72
0,30,72,0,-75,12,-60
90,42,72,0,-72,3,-72
In fact i can take the whole thing, scale it back by 1/8th and import it at 1:1 and it works fine.
I'm stumped.
Here's a simpler, skewed full-size arrangement that Revit will not load at full-scale but will do so when scaled at 0.8 or less.
; Written by HatchKitCS
; HatchKitCS (c)1990-2016 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 9/09/2017
;-Time : 1:28:01 PM
;-HatchKitCS Version : 3.1.10.2730
;%VERSION=3.0
;%UNITS=INCH
*tiles3;%TYPE=MODEL
180,12,0,36,37.5,12,-60
0,0,0,36,37.5,12,-60
0,0,6,36,37.5,12,-60
-90,12,6,37.5,36,6,-69
-90,0,6,37.5,36,6,-69
127.284894937,0,6,472.826710257,1.9753652155,39.601,-1327.23485335
52.7151050628,12,6,472.826710257,-1.9753652155,39.601,-1327.23485335
You can get arond this by loading the free Hatchkit Add-In for Revit then scale the pattern once loaded to your project.
- load the pattern scaled at 0.1
- open the HatchKit Addin for Revit
- find the loaded pattern and double-click on it
- Set the scaling factor at 10 to 1
- rename the pattern then Add to add a new fill or Replace to overwrite
If you have HatchKit installed, you can simply import the pattern directly to the project.
Hope this helps.
Edited on: Fri, Sep 8, 2017 at 10:52:52 PM
Edited on: Fri, Sep 8, 2017 at 10:54:11 PM
Edited on: Fri, Sep 8, 2017 at 10:55:07 PM
Hugh Adamson
www.hatchkit.com.au |
Oh sweet, that worked great... Thanks Hugh!
Here you go Jessicavuocolo. Right int he RVT file.
0 Posts No Rating |
Wow you all are the best, thanks - much appreciated!! One last request, are you able to save it in Revit 2017 - my project is not in 2018 as of yet. =-)
Techincally, no.
So I had to re-create it again in 2017.
But here you go.
0 Posts No Rating |
Bingo!! That works perfectly. Thank you again.
0 Posts No Rating |
Hi.
would anyone help me writing a herringbone pattern for 1200x150mm planks.
Thanks
Maybe start with this one and edit the family: https://www.revitcity.com/downloads.php?action=view&object_id=2965
Here is the pattern you are looking for. I already had a file with this size pattern in it.
Stray Lines in custom Revit fill pattern |
Mon, Jul 8, 2013 at 8:02:44 AM
Custom fill pattern with a background |
Mon, Jul 24, 2017 at 8:01:44 AM
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
fill pattern alignment |
Sun, May 3, 2009 at 1:28:15 PM
Members: | 1977463 | Objects: | 22860 | Forum Posts: | 152167 | Job Listings: | 3 |
