31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> extrusuin family not poched
I have created a trellis family with posts, that spans 2 floors. I can see the posts poched in the upper floor but not in the lower floor. I created a plan regiosn on the lower floor and placed the cut plane 5'-0" above the lower floor but still cannot see the extrusion poche. Please clarify how I can view the posts as cut in the lower floor, with a poche. Thank you in advance
Any detail items added to a family in a plan will only show in the project view that hosts the family. If you want a material poche, then the family needs to be cuttable and assigned the correct material.
You could add filled regions on the appropriate levels and group those with the family.
revit 2016 poche |
Wed, Sep 23, 2015 at 2:50:33 PM
Poche Walls |
Wed, Sep 22, 2004 at 8:50:39 PM
Greyscaling elements at a distance? |
Tue, Aug 16, 2011 at 11:51:05 AM
cut pattern override view template |
Tue, Mar 31, 2015 at 10:44:39 AM
Phasing & graphic overrides |
Thu, Apr 1, 2010 at 12:13:13 PM
