44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Template help Please
Thu, Jun 30, 2016 at 9:37:04 AM | Template help Please
jeffsdarton
All,
  I have looked until I am blue in the face and have tried several different things.  What I want to do is to have a view template that has multiple different categories in it (i.e. concrete, steel, wood, metal) detail components and modeled elements.  I want to make them look like I want using the view templates and I believe filters is the way to go but for an example, in the Structural Framing Category I have Concrete Beam and Steel Beams that are 2 different line weights so using visibility graphics is out of the question because that changes them both to one line weight.  Can anyone give me how-to's on how to go about doing what I want.  I am using Revit Structures 2015 for my templates and upgrading them to newer versions right now.
Thanks,
Jeff
Thu, Jun 30, 2016 at 10:27:54 AM | Template help Please
Detail components are only detail category.   To change these independently, you would have to have seperate detail component families with different sub-category elements.
Thu, Jun 30, 2016 at 10:38:44 AM | Template help Please
jeffsdarton
Thanks for the reply.  I get that but when I have 2 elements in the same category that need to have different line weights do i have to create a filter for each scenario, becuase the filter list would get long. there has to be a way to set up the view templates so that I do not have to overide lines in every detail, meaning I do not want to use this like autocad
Thu, Jun 30, 2016 at 2:26:46 PM | Template help Please
As I wrote ...."   To change these independently, you would have to have seperate detail component families with different sub-category elements."   Each sub category then can be controlled.  ie: Concrete Detail - New Detail Line sub-category named xxx will now show up under the detail categry.
I really don't understand why you want to do this.   The very simple light/medium/heavy sub categories should be sufficient for everything you do.
Thu, Jun 30, 2016 at 2:49:05 PM | Template help Please
jeffsdarton
Oh, Ok, sorry I wasnt followiong you.  I will try that so see if i get the results I am looking for.
thanks
ARCHITECTURAL TEMPLATE VS C0NSTRUCTION TEMPLATE
Thu, Sep 27, 2007 at 5:19:28 PM
Template Update
Sat, Jun 25, 2016 at 6:01:29 PM
Template to Project
Tue, Jul 31, 2018 at 2:25:32 AM
reloading updated template....?
Tue, Dec 16, 2008 at 12:07:45 PM
Template Version
Tue, Apr 22, 2014 at 2:02:58 PM
Page generation time: 0.0972
