Forums >> Revit Building >> Technical Support >> Plot stamp: Set file-path to Central
Tue, Jun 7, 2016 at 5:31:18 AM | Plot stamp: Set file-path to Central
Fryingpanman
Hi Reviteers,
This topic has been asked many times before on these Forums, without any good answers, it seems. So I'll re-open the topic:
Has anyone found a way to set the File-path label on a Title-block family to refer to the Central file location, and not the Local-file location?
To be honest, it pretty pointless to refer to a local file in this instance; since another person surely would want to see the Central File location in order to open a model & work on it...
Any ideas?
Tue, Jun 7, 2016 at 7:53:43 AM | Plot stamp: Set file-path to Central
The similar threads below has your answer - this post.
Tue, Jun 7, 2016 at 8:22:42 AM | Plot stamp: Set file-path to Central
Fryingpanman
Thanks, WWHub,
As stated, no real answer to my question in any of the related forum posts, including the one you linked.
Shall I thus assume that it cannot be done at all, besides closing my model and re-opening from the Central file each time I need to print?
Not cool...
Tue, Jun 7, 2016 at 8:33:00 AM | Plot stamp: Set file-path to Central
The real answer was in that post.  If you don't like that process, please put it on the Augi Wishlist.  Complaining here will not be heard by Autodesk.
Central File Path on a local file
Sat, Oct 24, 2015 at 10:21:20 AM
File Path in Titleblock
Wed, Nov 10, 2010 at 10:48:55 AM
Date Stamp on Drawings
Tue, May 29, 2012 at 10:10:13 AM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
Plot Stamp
Thu, Aug 20, 2009 at 12:39:57 AM
Page generation time: 5.0956
