6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Realistic Trees in Site Plan
I'm trying to figure out a way to have my trees in my site plan look realistic. I have tried a few things but so far nothing has worked. I would like to keep my visual style as Consistent Colors and show a realistic tree with some shadow. I attached an image similar of what I am looking for. Thanks for any help!
I thought you might be able to do it from a realistic view but the tees go away.
If you are only using Deciduous trees, you could edit the "Deciduous Base" family then using a realistic view - top orientation, you will have the tree shadows like my image below. NOTE: I obviously left that simple base.
I tried editing it and I couldn't get it to work.
I could do some 3D lines on an elevated work-plane in a special sub-category and that would show up but I could not get rid of the base pointer for the tree. I could lower the tree so the bas pointer disappeared. Image below is what I did... I did not take any time with this - just some splines that I mirrored around in the base family.
The problem now is the pointer base.
I'll have to take a look into it more. Seems like it should be easier than this!
Will the tree in the downloads work for you? I haven't used that one in a long time:
http://www.revitcity.com/downloads.php?action=view&object_id=2767
Tropical Trees |
Wed, Jul 20, 2011 at 4:21:46 PM
Rendering RPC's trees on site plan view! |
Mon, May 7, 2012 at 7:33:47 PM
Rendering problem(trees) |
Mon, Nov 16, 2009 at 10:05:39 AM
RAC 2011 realistic views and trees |
Thu, Oct 31, 2013 at 2:07:03 PM
turning on layers in plan and off in elevation |
Fri, Mar 26, 2004 at 9:06:39 AM
