Forums >> Revit Building >> Technical Support >> Face-Based Family loads "Inside-Out"
Fri, Apr 29, 2016 at 7:23:59 PM | Face-Based Family loads "Inside-Out"
Bartholomew
5 Stars: 2 Votes
Forgive me up front; I’m going to try and succinctly articulate what the issue is, but that’s a little challenging in and of itself. Anyways, here goes…
I’ve created a Faced-Based Family. A Ref. Plane named “Front” is locked to the Ref. Level and it is defined as the “Origin”. Inset from that “Front” origin plane – towards the center of the Host Face (negative Z) – is another named Ref. Plane named “Back”. I have geometry drawn on both these planes. Planes and geometry are parameterized and locked. So far so good – except when I load the family and place it on a Host Face; or a Work Plane that rests on the Host Face, my Face-Based Family loads “inside-out”. That is, it’s “Front” Origin Plane attaches to the correct Host or Work Plane, but the family’s “Back” Ref. Plane geometry is oriented in the positive Z direction; not the negative Z direction like it is in the family.
Get it? If so, your feedback would be greatly appreciated? I’m really feeling like a bone head here. I’ve created hundreds of faced-based families and I don’t think I’ve ever encountered this before. What am I missing?
If it matters…BDSP2016
Sat, Apr 30, 2016 at 10:18:25 AM | Face-Based Family loads "Inside-Out"
So you actually want your family's solids to be inside the host where they are hidden?
I guess I would have to look at the family.   Adding the front reference plane and locking it may be part of your problem.  There is no need to do that, just reference off the host face.  Is the Back plane parametrically located in relation to the host face?  You actually located that using a dimension in an elevation - correct?
Sat, Apr 30, 2016 at 11:28:28 AM | Face-Based Family loads "Inside-Out"
Bartholomew
5 Stars: 2 Votes
Thanks WWHub. Here’s what I discovered: My problem-child Face-Based Family has several parametrically-driven Arrays of Sweep Extrusions that are pathed along Model Lines. Although these Model Lines are properly anchored and associated to a Work Plane, that association is lost upon Arraying. I know this is typical behavior when you copy model lines. I suspect this is the root cause of the problem I’m experiencing. Still, it’s odd to me that the family loads “inside-out” as I have described. It may be that I chose the wrong family for the job. Bummer. As the saying goes: “The best laid plans…” yada, yada, yada.
Sat, Apr 30, 2016 at 12:01:41 PM | Face-Based Family loads "Inside-Out"
Bartholomew
5 Stars: 2 Votes
SOLVED! (U.N.O.)
The issue I was having had nothing to do with the family template I was using. It had everything to do with a “loose nut behind the keyboard”.  HA!
What I was trying to achieve was this: a family that I could parametrically-control an Array of several geometries together (in this case: Sweeps) in the X,Y AND Z directions.  In other words, “stacked” or “sandwiched” geometries that resides at the same X and Y coordinates (from the P.O.V.), but on different Z Work Planes – with the distance between those Z Work Planes being a parameterized value as well.
What I found out was this: Arrays don’t do “Z”. Try it. You’ll see that the Array spazzes out when the Work Plane on which it was created is moved. The Array works fine and dandy In the X and Y direction – but when you change the Array’s Work Plane elevation, the Array breaks in weird ways (such as inside-out) . Why? Because, the Work Plane is outside the group – not part of it. There’s no Work Plane “association” after grouping.  Duh.
For my purposes, here’s the workaround I found: Put all the sweeps on the same Work Plane then control their relationship to that “Origin” point by parameterizing the “Vertical Profile Offset” (the Z direction) of the individual sweeps. Still, this approach required some seemingly odd “jerry-rigging”, so I can’t be certain it won’t break later – but so far, so good. Flexes great. I’m Jazzed.
Have a good array.
Edited on: Sun, May 1, 2016 at 7:53:34 PM
Edited on: Sun, May 1, 2016 at 7:54:19 PM
Edited on: Sun, May 1, 2016 at 7:55:17 PM
Edited on: Sun, May 1, 2016 at 7:55:51 PM
Mon, May 2, 2016 at 7:34:01 AM | Face-Based Family loads "Inside-Out"
Glad you found your problem.  You might contact Autodesk with this.
Did you consider nested families?  If the array were nested and inserted on a workplane that moves, the break may not have happened.
Mon, May 2, 2016 at 12:12:06 PM | WWHub
Bartholomew
5 Stars: 2 Votes
Quoting WWHub from 2016-05-02 07:34:01
I don't think it's a issue to be reported. It's totally replicable. I believe this is exactly the way groups are suppose to behave: independent from elements and references not defined within them. I just never realized before that the Work Plane they are defined on would not be encorporated into the group. But, now it makes sense and explains why ref. lines, ref. planes and model lines, that are included in the group, become dissassocited from their workplanes after grouping.
Regarding the family: it cantains no nested families; just profiles for sweeps. Good suggestion though.
Thanks Again.
Edited on: Mon, May 2, 2016 at 12:18:37 PM
Mon, May 2, 2016 at 5:45:12 PM | Face-Based Family loads "Inside-Out"
Bartholomew
5 Stars: 2 Votes
WWHub: You're suggestion of nesting proved to be a much better approach. Albeit: a little more work up front, but much better results overall. Line-based GMs for the sweeps, nested into the Face-Based GM parent, was the way to go! Thanks.
Edited on: Mon, May 2, 2016 at 5:45:38 PM
line based family inside face baced family
Mon, Aug 6, 2012 at 9:15:42 PM
How create a face hosted "Plumbing Fixture" family?
Wed, Sep 21, 2016 at 1:55:44 AM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
Face Based Light Fixtures
Tue, May 12, 2009 at 5:57:35 PM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Page generation time: 1.5829
