Forums >> Revit Building >> Technical Support >> building a mezzanine
Sat, Apr 1, 2006 at 12:21:27 PM | building a mezzanine
gdoorn
1 Stars: 1 Votes
i am designing a 2500 seat hall with a mezzanine. what is the best way to build this? the mezzanine will be stepped for sight-lines and i have heard about difficulties of sloping a floor. my initial reaction is to build it as a stair and drop a ceiling under it to achieve the sloping underside. any help would be appreciated. thank you
Sat, Apr 1, 2006 at 4:15:17 PM | RE: building a mezzanine
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Would have to see it, but due to limitations of attaching objects to stairs i'd probably model an in-place floor, then if file size becomes an issue save out the floor as an external family and load it back in... HTH.
Sun, Apr 2, 2006 at 6:11:18 PM | RE: building a mezzanine
geoffy
What about creating a profile of the floor/ stairs and then sweeping that as a mass profile?
AutoCAD & Revit TAFE teacher from regional Australia
Mon, Apr 3, 2006 at 12:09:34 PM | RE: building a mezzanine
gdoorn
1 Stars: 1 Votes
What about building 14 12" thick generic floors, and offsetting the front face 36-42" (the depth of my rows). then dropping in the aisle stairs as a series of single riser stairs? my Mezzanine is only 12-14 rows deep, are there any potential problems to this method?
Stair Showing Below Mezz Slab
Thu, Jan 26, 2012 at 9:23:25 AM
Floors show in all Views but 3D
Fri, Jul 20, 2012 at 6:04:17 PM
Filled regions and viewports
Fri, May 6, 2005 at 3:21:44 PM
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Phasing and penetrations
Tue, Jul 28, 2009 at 10:08:39 AM
Page generation time: 0.5361
