6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Spell Check stopped Working
39 Posts No Rating |
Hi
Using Revit 2009 Arch, and my Spell Chek just suddenly stopped working. When I hit F7 (or the Spell tab) nothing happens. I have chekced the Options>Spelling and the Main Dictionary is set to the only option Autodesk Revit (US English) as the Microsft Office button is grayed out.
Any help on how I can fix it will be greatly appreceated
Cheers
Did we have spell check in 2009 version? I didn't think we did.
In older versions, Revit's Spell Check function only checks what is in the current view. To spell check a project, each referenced view must be opened and spell checked.
Yes WWHub I have to check each view in 2009... usually after checking a text note it would ask if I wanted to check the rest of that view...But now suddenly NOTHING happens when I try check the spelling..its like the ability to check the spelling has just disapeared
Edited on: Fri, Oct 2, 2015 at 10:13:30 PM
You may have to re-install the program.
Thanks ..will give it a try
Spell Check and Text Format |
Thu, May 22, 2008 at 7:11:35 PM
Spell Check of sheet & view Names |
Wed, Mar 5, 2008 at 10:01:45 AM
Spell Check Entire Project |
Wed, Jun 28, 2017 at 10:16:49 AM
Spell Checking in Note Blocks |
Wed, Dec 20, 2006 at 7:13:54 AM
spell check |
Mon, May 22, 2006 at 1:22:57 PM
